  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
if i was a salesperson yeh :), im a PR rep
More money in sales you know :)
and if you become Corporate PR officer you have to sleep with the clients, I am sure there are plenty of C-level execs out there that would take a fancy to a 19 year old boy :cheers:
yeh more money in sales, but everyone hates sales people, after cold calling on saturday i feel real sorry for telemarketers now :cheers:
"Below the line" sales, like telemarketing and cold calling out of the phone book are crap.The only person who makes money out of that is the owner of the business.
You need to be looking at things like Corporate Accounts Manager, Corporate Business Development Manager, Corporate Sales Manager...... all those are 60K to well over a 100K positions.
yeh after the amount of abuse i got on saturday cold calling, im not going near the phones unless i have too.
and those manager positions all come with experience which i dont have yet.
Yeah true..... it has taken me ten years to get to be a Corporate BDM.
The last 2 and a half years of running Umart were driving me up the wall, but it was a means to an end and I am glad to be out of there.
At least you are going in the right direction :cheers:
$50.00 out of someone elses sale is good on top of your base.
It helps if you don't look at it in the short term.
Take a longer view of your commission and add everything over a monthly or quarterly period. It adds up to much more than you think. Especially if you are getting a half decent base.
You have to ride out the less lucrative times with a view to the future, build and retain a client network, because you can use those people as a business reference when you have enough experience under your belt to start going for the big money jobs.
Don't be discouraged, stick with it :rofl:
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
