  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well if you are gunna do it, please make it interesting.
Tell some jokes or teach us something, don't just mindlessly post rubbish about what you are eating, what is on TV, the weather outside etc etc
you know, classy whoring
sorry mate.. will get some new material for next time. :D
you didnt last long did u  :headspin:
had a goddamn meeting to go to. plus work. plus set up a user from vancouver so he can recieve his mail here in wa and kalgoorlie. and fix another user so he can get mail in tanzania... good fun but gives me no time for whoring.... :rofl:
This might sound disgusting to you guys but it's pissed me off.
I bloody go and get a papsmear like the stupid government likes us women folk to every 2 years.. and the ****ers charged me for it! $50! WTF. "go have a papsmear" "Here have a bill too".
Theres a medicare claim form in with the invoice, so maybe I can claim some back. Just sucks. Especially when I'm running really short on money :rofl:
EDIT: Might I add, plus the $41 consultation fee. So that's like nearly $90 all up. :bs!:
*sigh* I might go get some sleep i thik
