  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol in disneyland in tokyo i was running past a guy dressed up like a big pig
and i slapped the back of his large fiberglass head
he made some rude gestures at me
and i thought japanese were polite people :cheers:
immah do that ;) and yell 'remember me!' on the way past :rofl:
internal sales, im guessing that they sell between each of borals subsiduary companies
ie if boral owns company x and company y. boral will sell to both of those companys but they are classed as internal sales due to them being owned by boral?
just a guess :cheers:
the company i work for sells to itself and counts it as profit in it's ann reports :bs!:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
