  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Top 10:
chaos 6485
Ska 5353
BelGarion 3724
predator 3207
Nexus9 3079
strutto 3038
Genesis® 2674
Lazy-Bastard 2392
SmoothLine 2221
Charly 1833
You should take 9th preety easy considering Smooth is AWOL from SAU.
Nu ah, I didnt post up f5 by itself, strutto's post specifically stated that if f5 was posted by itself it would get a ban! :)
CLEARLY f(4+1) but itself is NOT f5, might be the same mathematically, but CLEARly not the same!
Top 15:
1. chaos 6485
2. Ska 5353
3. BelGarion 3724
4. predator 3207
5. Nexus9 3079
6. strutto 3038
7. Genesis® 2674
8. Lazy-Bastard 2392
9. SmoothLine 2221
10. Charly 1833
11. NismoGirl 1826
12. Eug 1550
13. TeamKrazy 1493
14. jaqule 1423
15. NA_R33 1374
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
