  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
67.4% of my total posts are in here....hehe
I'm at about 55% Whore - 45% Knowledgeable Skyline Geneeus... But that doesn't include the massive amount of knowledge I have spewed forth in this thread to help people such as...
Ska 80% Whore - 20% Dumbarse...
I love sleeping in....is there a job where they pay you to sleep?
most government call centres?? :) Oh no you cant sleep there, but you dont have to do any work or be friendly to anyone except your boss....
TPG at the moment, 1.5Mbps capped to 64Kbps after 20 GB.
I have been over that heaps of times but this month they have bought down the hammer :)
When I worked at Umart we used Bigpond adsl as well and reguarly got 60-70 GB downloads a month no questions asked.
I think it is coming on TV in Oz in February.
It shits all over the old one.
This one is very adult orientated, with lots of twists and turns and subplots.
Probably the best Sci-Fi series I have ever seen.
The Battle scenes have to be seen to be believed.
but of course sir
The pilot episode is about 3 1/2 hours long takes a little bit to get going, but once the players are introduced and the action gets started, it doesn't let up the whole series.
It feels claustrophobic, the pressure is constantly on all the protaganists and there seems to be no release.
The European Commission has just announced an agreement whereby English will be the official language of the European Union rather than German, which was the other possibility. As part of the negotiations, Her Majesty's Government conceded that English spelling had some room for improvement and has accepted a 5-year phase-in plan that would become known as "Euro-English".
In the first year, "s" will replace the soft "c". Sertainly, this will make sivil servants jump with joy. The hard "c" will be dropped in favour of "k". This should klear up konfusion, and keyboards kan have one less letter.
There will be growing publik enthusiasm in the sekond year when the troublesome "ph" will be replaced with "f". This will make words like fotograf 20% shorter.
In the 3rd year, publik akseptanse of the new spelling kan be expected to reach the stage where more komplikated changes are possible. Governments will enkourage the removal of double letters which have always ben a deterent to akurate speling. Also, al wil agre that the horibl mes of the silent "e" in the languag is disgrasful and it should go away.
By the 4th yer peopl wil be reseptiv to steps such as replasing "th" with "z" and "w" with "v".
During ze fifz yer, ze unesesary "o" kan be dropd from vords containing "ou" and after ze fifz yer, ve vil hav a reil sensibl riten styl. Zer vil be no mor trubl or difikultis and evrivun vil find it ezi tu understand ech oza. Ze drem of a united urop vil finali kum tru.
Zen ve vil finali rul ze vorld!!!!
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
