  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey Cyrus,
do you know what dictated which SAU QLD Member number you recieved?
was it first in best dressed?
I want details of the 14 before me!
You'll never get 1, that's his :) but yeah was first in best dressed apparently.
i got nothing!!!! i suck at this, if you have to tick the little box next to the bit where it says "quote msg in reply?" i cant tick the box, then there is the bit where it says "wrap quote tags around selected text" up near where the bold letter icon is?? there the only ones i can see. and i still got nothing. i suck!
