  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
okay found the track listing for the soundtrack
1. Are You Alive? / Battlestar Galactica™ Main Title 5:28
2. Goodbye, Baby 2:24
3. Starbuck Buck Buck 1:49
4. To Kiss Or Not To Kiss 2:42
5. Six Sex 1:48
6. Deep Sixed 1:59
7. The Day Comes 1:08
8. Counterattack 2:40
9. Cylons Fire 1:34
10. A Call To Arms 1:03
11. Apollo To The Rescue 1:56
12. Launch Vipers 4:26
13. Seal The Bulkheads 2:10
14. The Lottery Ticket 3:06
15. Eighty-Five Dead 1:23
16. Inbound 1:23
17. Apollo Is Gone / Starbuck Returns 2:19
18. The Storm and The Dead 2:40
19. Thousands Left Behind 2:09
20. Silica Pathways 3:32
21. Reunited 1:56
22. The Sense Of Six 3:01
23. Starbuck's Recon 1:11
24. Battle 7:40
25. Good Night 2:38
26. By Your Command 1:56
Total Time: 66:01
