  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ooo..new look..so maybe some good will come out of this.
yeah, thats the thing motivating me to get mine fixed. If i can get the new sideskirts fitted it will make the car a fair bit different to look at, so while i already know what it looks like "non-multicoloured", have no idea how it will exactly look with the whole 400R kit. Will look a lot more consistent too.
