  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Mona Lisa Smiles.
It was "ok". Didn't end the way we thought it would. Things didn't happen the way you predicted them too... Was weird. But hell! I'm glad I live in today society where I'm not accepted as nothing more than a house wife.
It's really eye opening to see how people were taught to live back then. You were to go to school, get an education, get married, have children and just live.
Hey if you ppl go to this thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=35552
You'll see Philly's reputation is "On a distinguished road." what's with that, did he get a heap of good reps or something?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
