  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
If it's a proper dyno, I will consider it... If it's one of those mobile ones, like the dodgy one that was advertised on boostcruising (a dyno set up out the back of an industrial estate... I won't be putting my baby on something as dodgy as that.
WTF?!?
Now that will be nice and accurate I would imagine :blah:
I want one last run before work gets under way, just to see what I am running now.
I haven't actually had a Dyno test since it was stock, but I am like Pred it is in desperate need of a GOOD tune, so I will take what it pumps out with a grain of salt methinks.
They put your car on a roller, most of them are built into the ground, others are above ground. But on the rollers they get the car into 4th and plant it basically and it gives you a power figure...
I was soo nervous the first time my car went on one, I was shaking severly and everyone could see it. I wasn't worried about the power output, more the fact of things blowing up. But Sinbad was very good and didn't break anything :)
