You dont know what love is until it has come and gone
True True :D
I have found that out a couple of times the hard way.
I have, in my dotage, learnt to appreciate those people I love and show that appreciation frequently
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
but I think we both just had our sponge bob cranky pants on :rofl:
Good example of adults putting a small difference of opinion behind them and moving on.
Pretty easy to do when someone is as nice as Erin and I :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
