Can't say that I watch much TV anymore, even with Foxtel.
About all I watch is The Simpsons and Futurama...... oh and just about anything that comes on the Discovery Channel I will sit down and watch.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Best advice I can give you for a happy career is to find something that interests you enough, that you would do it even if you weren't paid.
Example...... I love computer hardware and even if I didn't work in the industry I would stiil be playing with the hardware in my spare time.
It is lucky for me the the I.T is also an industry that pays reasonably well, but regardless of pay rates I would still be involved in some level or another.
The hard thing is finding something that interests you that much...... and I think, that's where you need to look at the hobbies you have that bring you enjoyment, and investigating in career paths within that interest.
Good then we have something to start with.....
You now have to decide what areas of I.T interest you..... example I like computers but I hate coding, bores the shit out of me, but others love coding and hate the other acpects, like data admin, network admin, hardware/system design.
Each person is different, doesn't mean that their interest is better or more worthy than yours.
So even though you are interested in I.T you might find yourself in an area you do not like, but are still in the I.T industry
