  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oh nexus while i remember im in the market for a new monitor mouse and keyboard...would it be better for just a new computer?
Only upgrade your computer if you can't run the programs you want to your satisfaction, otherwise the keyboard/mouse & monitor option is good.
Would you 2 like your own little conference room so you can have a nice little meeting where u sit around and don't really get anything done??
No thanks I prefer everybody else to have to wade through pages of uninteresting crap if it is all the same to you :D
Heheheh
hey strutto.. i think somebody is trying to upsurp your authorit-i by just going to post in general instead..
drewecrome: HELPHELP Hey, i was wondering if the seris 2 r33 gtst skylines have a differnt turbo, i guy from a performanc shop told me that the turbo got better in the seris 2 r33's, is this true? Also i will be in the market for an r33 gtst, in june, do u guys think i could get a decent r33 gtst either series 1.5 or 2 for $19000, i dont car bout mods, i just want a nice r33 gtst, hopefully witha nice kit.
any help?
he doesn't really get the idea does he?
which would you recomend brand wise cause we want a flat screen mointor and cordless mouse and new keyboard.
There is only one cordless Keyboard/mouse to look at... the Logitech MX Duo, don't bother with anything else
In regards to monitors I have said it before and I will say it again, the "BenQ FP737"
Yeah dont bother with the microcrap cordless, my work insisted we buy 10 because they have a longer range than the logitech, too bad the users sit 2 metres away from each other and all the keybords andmice conflict with each other........ fun fun fun!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
