I should be getting the 31 at least tomorrow night.. but its going to need a few things done before its on the road. The diff replace is going to cost a bit more than i thought, so 'project get skyline same colour' may have to be on hold for a few weeks.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
evenin' all,
Question about the hybrid intercoolers....why does everyone shitcan them???
I have been looking around for some bad reviews, but can't seem to find much info at all. What's the go...are they leaky? poorly made or what?
Or is it the fact that they are manufactured in China?
Anyone got a definitive answer or is it all just heresay?
Hi Warrick
yeah I would like to know too.
When I was discussing with Gavin Woods the future mods for my car in regards to the power I want to acheive, he said not to touch the Hybrid as it didn't flow well enough for high powered cars.
He said it was good for up to 200KW but after that it just doesn't cut it.
So consequently I am madly saving for a new Trust intercooler
Hmmmm....Ok, well from what I have read on this forum, Gavin knows his shit.
So these "Hybrid spec" intercoolers (apparently made in the same factory), such as the ones mindflux is trying to do a group buy on are essentially the same thing I presume, and in that case to be steered clear of.
the hybrid coolers are fine .. ive got one on the way, however if you wanna run high kilowatts, then you best go for something more expensive. i dont plan to hit 200kw so i feel one of these coolers would be perfect for me.
other peopple bag them because there cheap they assume 'if their cheap its shit; .. other people jump on the band wagon 'oh wasnt made in japan must be shit'
yamutha - im not 'trying' to do a group buy .. i have already got mine ordered, infact ive had it eveb before the group by .. i was just letting people know about these intercoolers as i know there is alot of people after these intercoolers.
baah ill explain after i get away from the TV
bbs
200kw is all the hybrid can cope with ? even the stockie can do better than that most of the time.
for up to 300rwkw or so even the GTR cooler is all you need.. "all over again".. GTR cooler, custom stainless steel piping.
Generally the Trust I think is "the" best regarded cooler in japan.. the others come somewhere after that.. HKS isn't bad either, although i'm biased :rofl:
