  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Got a bit pissed at me when i laughed at him, that was after he asked if my horns were musical
Should have said: "My horns musical? nope, but boy, should hear the noise about to come out of my ass".. and let one rip :)
Yupp shell on left past nerang, past exit 74 or sumthin, looking for a shell and or a hungry jacks, I'll do my best mindflux, hopefully john knows it :) he's got your number so if we get lost give ay a ring :D see yas out there, better go have a shower :D benefits of living 2 kms away from BP Yatala:D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
