  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mornin' .. where u go look for glow worms last night?
I dunno. someplace past the currumbin rock pools ask Mat he's the one leading, no it was fun, got to actually walk arouns and look at something different for a change, but you really had to be there at the servo, john has the idea, next week we'll bring deck chairs, the entertainment is just priceless!! :D
Probably not a good idea, my boss is coming down from Brissy in about half an hour so I will be busy for the rest of the afternoon then,
but pred should still be here till about 2.30 -3.00 if you want to chat to him :D
Cool well yeah I just want my tyres black for the photos after the caliper painting session tommorrow, not really worried about keeping themblack, yeah for $3 what can you expect, I guess maybe 1 or 2 days before it wears off :D
You still want some, cause it'll probably be next thursday we see each other, plenty of time for you to drop into a warehous somewhere and grab some.....?
