  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
AHHHHHHHHHHHHHHHHHHH
wusup man! .. i just got home, its like bloody 5.30am .. been out with Owned for the night.
went down to somewhere in NSW was crazy.
Oh to the gusy that went out on friday night .. on my way back to the petrol station (was filled with car ****s, at least 20) .. you remember that white commodore that looked like shit and spun the wheels on belts ... i drove past him while he was exchanging details with a festivea he hit lol!!!
man what other exciting shit happend... oh my headlights are ****ed..
Also when your breaking from doing 170 (this was on a legal drag strip) and your breaks start to shudder .. what does that mean?
