  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Ok .. Amandas a dead set champ ... gav on the other hand gets me puzzled most of the time.
I'm having issues with real names atm, im like 'i was spekaing to greg' .. and then she puleld up your profile .. im like his plate is hex something or other..
and shes like .. Oh Chris?
and im like wtF? .. yeah thats him ..
and shes like, yeah i remember most cars by their plates .. (ironic how she remembed my car as 'the hail damaged r32' lol :D :D)
And i was asking her about cross drilled breaks .. and shes like nah you dont need them unless your going to be drifting and racing alot, and im like .. nah i've kinda retired.. my gearbox is screwed from all that :(
Just wondering is i should for out the 500 - 600 for slotted rotors .. or just keep my same ones ..
She told me, $165 including machining and labour and bendix pads..
dont know how true to his word he is though? .. cuz im still kind of up in the air about it, as he told me he checked my tyre pressure, and 2 days later i had to pump it up due to them being flat. :S :S
So i don't know what to think just at the moment, ill give him the benifit of the doubt and assume my tyre was flat from my weekend of madness..
Hmm..
Edit: Im not bagin Gav or anything.. im just making a statement, due to my prevous experiences with workshops ..you wouldnt blame me for being paranoid and suspicious
alright .. ill just check that transaction for you ..
as for piping, i know a member of these forums got some mild steel? piping done for $450
im hoping to possibly do a group buy on piping .. where ill have a word to some workshops and see if they can do X amount of cars for a cheaper price..
Wade - that should be fine by me, i will get my cooler about 2 weeks before you .. but im happy to wait ...
will you be supplying 2 cars? or just the one?
I noticed another member was interested in getting some piping done, so i'll have a word to him too .. and if he will be in that'll make 4 cars.
I will ring around a few work shops on the goldcoast and get prices soon .. i dont know of any workshops in brisbane .. so uhmm yeah :S ... apparently the cheapest workshop on the goldcoast is Ashmore exhaust .. doing it at $450 including pipes, bends.. pretty much all the shit. a member of the forum got his work done there, and he ahs invited me to check out the piping as he lives close by, and i may take up the oppotunity and hopefully get some photos.
However having said that .. i did speak to a 'friend' that said they were shit bla bla bla .. however i think he might be just jumping on the band wagon .. im unsure.
I will like to grab the lads that would be interested in this group purchase and discuss what kind of pipes and that so i have some amunition to speak to a few workshops about.
Nexus - how will i know when they need replacing? ..
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
