  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Alright going to keep a count of cups of coffee today, but to make it fair 1 cup = 1 teaspoon of coffee and 2 teaspons of sugar, so the way I drink coffee it is 3 cups at a time sometimes 4 as I usually have 3 teaspoons of coffee and six teaspoons of sugar, so I am starting on cups 1 2 & 3 now:D
bored ska?
Nope just trying to whore my way up to past chaos :( gonna take me a lot more whoring than this though as I am expecting like 50 pages of unmitigated crap when I arrive home tonight from the cruise!
Hmmm just been informed I'll have some passenders tonight, so no hanky panky for me :( Also I put my hand up for being last in the cue again, as long as NismoGirl is in the middle of the pack or someone like her who will actually listen to my pleas to slow down or stop :)
See it is easy to whore like chaos, just need to be motivated to and have the time to waste, niether of which I really have at the moment............... should be working on code, but also got management meeting coming up, what a waste of time, get together and talk about what they want me to get done, I say just send me an email :( easier, then I can sit here and whore more :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
