  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah right, so how do you think the semi-slicks will go tonight ? :( Also I'll volunteer to be last again :) but hopefully you guys will hear my pleas of directions or to slow down.
Prolly wont need the buddy system onyl a couple of roundabouts to go through :)
