I think the pages of ben's crap should be deleted...
This thread is where everyone chats and builds friendships... Its the main reason along with the thursday meets that qld is now one of the strongest sections, where it used to be the weakest... There are new people every week, which echos well when the club is set up in terms of paying members...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
An idea that was brought up a while ago was a private section for the people who we know and trust...
I think we have enough people at the thursday meets to warrant a private section for talk about private activities and to also make life easier in organising the private events... Im sick of talking in code :)
PS: did i say private enough?
Strutto, other states have it and I think its worthwhile...
lol.. its just syndey mate.. but some from melb aren't much better I'll admit.
Pred - how come you were a no-show last nite?
I'm a girl.. may as well just admit it as that is what everybody has accusing me of :) nah, just too much driving in too many days.
Good to see another female join up... we had two new ones last night... they seemed to get along with everyone pretty well which is great...
Was a damn nice car too, she even has an after market diff... Would kick 90% of our asses down the strip as well. damn impressive...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
