  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i was driving out of the estate thats about 100m left of when you turn off from the highway....i saw a white r33 looked exactly like urs so i was damn sure it was you
Bout 1am? yeah that was me, I saw a car coming down anaheim drive :stupid: didnt see it was a skyline though... :/
