Just like to say that I in no way mean to be disrespectful of any service men and women that served in the vietnam war and any mental or physical pain and anguish that they may be still going through by my last post!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hay ska......you fitted that pod? *hatches devious plot to keep ska awake*
Nooooooooooooooooooooooooooooooooooooooooooo
OK now this is last post, turning computer off after it, nope have not yet, was thinking of going round to strutto's place tommorrow arvo to get his expertise help to fit it, areyou available strutto, bugger it now I gotta wait,
But of course... The //GC Pit is always open...
