  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey ska i got some nice green paint for you
Cool I am looking at going a bit green crazy and painting anything plastic green :( so yeah I dont mind:D You gotta get a airbrush and get some practise in and do the hulk on my bonnet :D
HELP TO FIT IT??????.....you bloody great GIRL!!!.....it's a 15 min job!!
BAH I own 3 tools, 1 phillips head screw driver, 1 small shifter and myself. How am I supposed to fit it with any of those, none are usable! ;)
nah ska i know your there you get my 2nd pm??
Sure did and will give you a burl if I am over your area, but will be from public phone as I dont own a mob phone :D
NNoooOOoooOoooOOoooOoooooo............
Yeah but you know what they say, you just cant keep a good whore down! :D
hmmmmm it has started to work already I just did 4 posts in one! These anti-whore patches must be working :D
Kids are awake, thank god for 5 disc dvd player, I can stick in finding nemo, barbie swan lake, cat in the hat, brother bear and just hit play :( then I go back to bed, if there are any probs my daughter knows to get me :D bit lazy I know but it is just so I can sleep a bit more and then make them brekky without them hanging round my feet ;) esp with bacon & eggs, dont like the kids hanging round cause bacon splatters :D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
