  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i have a spare room $75 a week +bills and $300 bond. no driveway though, as the dual garage is full (my line and other car).
atm i have myself and a mte living here, and maybe someone else moving in, its a 4bdroom house in a quiet place on the east side ( wakerley ) add me to msn if you want somewhere else. only thing is you need a job :P dont smoke inside and no pets
zoix: definitely need a driveway and probably prefer at least 1x garage.. and presently i have 2x cars so yeah, don't think I could move in. Thats going to be one of the main difficulties.
Thinking of just finding a place a bit further out so i can get a unit. Don't give two shits whether i live too close to the main strip or whatever, in fact some reasons its beter than i don't.
yeah..got job, no pets, got bond.. blah :P
When your enemy is far be as if he were near and when he is near look like you are far. rittle glasshopper yuo have much yet to rearn
I read Sun Tzu's art of war and I swear the whole book read like that. All these management gurus swear by the book and tell all these business execs to go read it, it's such a heap of crap.
speaking of diet fads. I was reading some stuff yesterday in the economist on stomach stapling in the US. You know when you're really really fat, so they cut you open and staple up your stomach so you can't eat much. Apparently they do like 120, 000 of these operations a year compared to 13,000 eight years ago. The scary thing is that about 2 percent of the people die from the operation. 2 percent of 120,000 is 2,400 a year from getting their stomachs stapled in the us alone. Obecity is set to take over from smoking in the next few years as the gretest killer.
That whole concept just makes me sick.. erk.. Do they actually use like a monster stapler or is that just a term they use.
Death by stapling ! I like it.. but for some the quest to change themselves is worth the risk.
Yup, well there are a never ending supply of fat ass americans I'd imagine.
Just like the chicks who get the boob jobs and then a year later there boobs have fallen off or something and then they have to have a mamory op and look worse than ever. The price of vanitey!
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
