  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i have a spare room $75 a week +bills and $300 bond. no driveway though, as the dual garage is full (my line and other car).
atm i have myself and a mte living here, and maybe someone else moving in, its a 4bdroom house in a quiet place on the east side ( wakerley ) add me to msn if you want somewhere else. only thing is you need a job :P dont smoke inside and no pets
zoix: definitely need a driveway and probably prefer at least 1x garage.. and presently i have 2x cars so yeah, don't think I could move in. Thats going to be one of the main difficulties.
Thinking of just finding a place a bit further out so i can get a unit. Don't give two shits whether i live too close to the main strip or whatever, in fact some reasons its beter than i don't.
yeah..got job, no pets, got bond.. blah :P
When your enemy is far be as if he were near and when he is near look like you are far. rittle glasshopper yuo have much yet to rearn
I read Sun Tzu's art of war and I swear the whole book read like that. All these management gurus swear by the book and tell all these business execs to go read it, it's such a heap of crap.
speaking of diet fads. I was reading some stuff yesterday in the economist on stomach stapling in the US. You know when you're really really fat, so they cut you open and staple up your stomach so you can't eat much. Apparently they do like 120, 000 of these operations a year compared to 13,000 eight years ago. The scary thing is that about 2 percent of the people die from the operation. 2 percent of 120,000 is 2,400 a year from getting their stomachs stapled in the us alone. Obecity is set to take over from smoking in the next few years as the gretest killer.
That whole concept just makes me sick.. erk.. Do they actually use like a monster stapler or is that just a term they use.
Death by stapling ! I like it.. but for some the quest to change themselves is worth the risk.
Yup, well there are a never ending supply of fat ass americans I'd imagine.
Just like the chicks who get the boob jobs and then a year later there boobs have fallen off or something and then they have to have a mamory op and look worse than ever. The price of vanitey!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
