  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmm.. true.. thursday can't possibly be a rest day can it? :P
Maybe it can just be a meet then? I'm happy to find some nice routes and eventually plan one, just takes some time.
BAH who needs planning, I didnt plan my mountain run, I just pulled a UBD out and went that looks good!
really? I thought u might have known the route. I prefer to drive it first.. I have an idea that I went on when I first came to QLD. Down Goldcoast way. Its a bit hairy scary though.
Anyhow I've done the honours so at least people can argue about where to go.. hehe
but I have to remember which way it was :P lol
Nope never did it, so we did make a couple mistakes, like zooming past the first stop point at breakneck speed, blame strutto though I was the passenger and said, yupp we just went past where we were supposed to stop, oh well :P
*looking around for GenesisR32 Antagonist aka yamathu33
no more unquoted quotes from you eh? you lucky.. my usb ports died on my last night when JL came by my place to hook up his digi cam... been using alot of 'tab' just to type this msg :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
