  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
just for sending PM's I am used to just using my addrress book when sending emails, and on other forums I go on, got addressbooks, havent seen one with this software yet, must admit have not looked hard though, thought buddy list was the answer, obviously not!
Bah train, BAH I'll come get ya, cant fit any furnature in da line but clothes are fine, problem is that I only got a queens size bed for ya, nothing else, like no draws or anything................... hmmmmm let me have a think about that might hit up a couple freinds for furniture, they owe me some :D
eewwww I got sheets dude, :D and hopefully you will use them, or the bed gets stinky, :) just dont have anything else, oh I do have a hanger thingy you can use, I got a built in in my room I can hange stuff in :)
FRUKING COMPUTRE BAABABABA I swear I'm gonna SMASH IT! half way through running HUGE OLAP report, friggin thing dies!!! been working all friggin day on it, dats why posting so much, cause have to edit a bit then run, waiting for run = whore time :D
chaos - nope a while back i had a pretty drunk/funky party and a freind decided he would go through and destroy some of my furniture, he thought is would be a funny joke, really funny, I found it hillarious, so he owes me some :D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
