  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
235's aren't bad.. what i got.. but i'd prefer 245's .. lol
nah man....235's...I reckon youd regret it if you got 245's + you'd get roll on your tyre wall and bad understeer unless you have some wide ass front rims
i've got 17" rims? 235 don't provide enough grip at the rear.. true i've got fairly poxy treads but still..
at the rear, yes, go 255's or larger if the rim width will take it, but not at the front 235 max IMHO
jaqule: unfortunately not .. i bought another car so putting the sideskirts is another 3 weeks away. Are you back in brisbane now? I thought you were in townsville?
moved down last week , looking for a place , and waiting for my line to be finished
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
