  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Man you have no idea how horrible it was.  Trust me, it wasn't going to make it.
i can vouch for James... he's not the sort that goes around killing helpless like animals....
humans yes... but definitely not animals....
I understand James.....even though it probably seemed cruel at the time, I'd say it was the most humane thing to do
