  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah cusco $80 if u still want. I wont be out thursday nght no more cos my grl got beatan up by sum guy last nght so ima going hunting.
Can I come and pick it up from your work on thursday?....I have the day off
Who the hell does that s$%t , matbe the crooz should be all ok us around your area , a bit of a SHOCK AND AWE campign , and smash the mofo
zac: you're not just going up to some guy who your girlfriend *reckons* is the guy?? seen stupid shit like that happen.. wrong guy gets smacked.. turns around with 10 of his buddies.. and entertaining violence ensues.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
