  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah.. smooth has the right idea :( best comeback for a overly religious family :)
if being nice fails just give up, be a prick and move on :D sorry, but its how the world works sometimes.
ok.. if u have already or close, often they're just scared that is the only reason you are with her.. so try and reassure them its not because of that, but because you really have something in common and that you have generally honourable intentions. Often they are too stupid to listen, but its worth trying.
yeah.. smooth has the right idea :) best comeback for a overly religious family :D
:werd:
If not... then...
"its not meant to be' :(
i guess it depends.. i mean if somebody had a definite intention to provoke something out out of the blue, i guess u defend those you know..
like the other week (sure we were drunk) but we were refused entry to this place.. my mate started asking "why" and getting a bit narky and acting like a bit of a knob, but still it was all pretty much verbal.. then this bouncer took offence and was all winding up a punch ready to hit him just because of a verbal insult.. u don't do that just because somebody calls you a dickhead.. it was nearly all on there as soon as he did .. lol but i think he backed down because he knew where it was heading.. and it would'a all been on tape.. my friend getting decked.. me hitting him, me getting decked.. probably us getting back up again.. :bahaha: actually would have been funny as we were all drunk
anyhow.why we even talking about this?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
