  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Umm the one in the Drag database up the top or one of the ones on my website?
on your website ...
my bad... you have 2 sections... one as purchase and the other with mods.
i just studying the figures becos i'm really surprised at how well the autos skylines go.
on your website ...
Yeah first one was the day I bought it... First time on the strip...
2nd time was with a few mods but I muffed pretty much every run so I probably could have done better...
I've got the slicks now so the 60ft times should be much better and thats the deciding factor in a good ET...
Also done some mild tuning on the SAFCII now and I'm heading back on 14/4 to hopefully get a low 14...
correct me if i'm wrong... but with autos.. the timing is much more consistent right?
The runs are much more repeatable yes... Mainly cause you just put your foot down and go...
But if you stuff the run up by leaving it in 2 and hitting the limiter, or accidently bumping the snow button :D, the times go out the window...
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
