  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Click below...  Click the attachment...  Then go to the main QLD forum and click on the bit I highlighted...
http://www.skylinesaustralia.com/forums/sh...&postcount=8531
All will be clear...
FLASHBACK!~~~!!!~!~!~!!~!~!~!
jeez dont give them fuel to put me to light :flamed:
but all silliness aside.... yeh he's ultimatley right in the end so i'll be a no show this week....
No I wasn't being silly... He is right... It's not something you want to attempt for the first time in the dark... Especially if you haven't owned the car for long...
i am not dissing you, nick.
i can jolly well say and post more... but you get my idea. its for your own good anyway.. and you fkn know it too.
