yeah, i think that is one of the reasons I stopped buying phones. They moved from the simple to out of control with too much stuff I would never use myself anyhow. Good old 8210 is fine for me -- if i ever change i lose my old cheap workplan.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I loved my 8210.. Then I got greedy and wanted a colour screen one. I bought a GD68 and I've hated it since the day I got it and I can't upgrade until august or some shit.
****en stupid phone. I regret getting rid of my 8210. I loved that little phone.
I guess the lesson is that greed doesn't get you anywhere!
Hey warrick ;)
Umart is only part-time at the moment, chris hired another guy at the same time who works when I'm not working doing the same thing. Basically as he needs an extra person in there 6 days a week. But its worked out well so far, allows me to do other things.
Believe it or not I don't think he owns a skyline either ;)
but Umart has been good so far.
GD68 ? what brand is that? or has nokia changed their naming.
my 8210 had problems when i first got it, but after they fixed it been fine ever since. And i've dropped it, got it wet, i think thrown it, and it lives
warwick: speak in emoticons -- see whehter you can do it! ;)
I'm with you guys on the phone thing, I only upgraded from a 5110 to a 8250 lol about 6 months ago.
The more gadgets and crap they have on them, the more inclined you are to use them for pointless crap which just hikes up your phone bill
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
