yeah, i think that is one of the reasons I stopped buying phones. They moved from the simple to out of control with too much stuff I would never use myself anyhow. Good old 8210 is fine for me -- if i ever change i lose my old cheap workplan.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I loved my 8210.. Then I got greedy and wanted a colour screen one. I bought a GD68 and I've hated it since the day I got it and I can't upgrade until august or some shit.
****en stupid phone. I regret getting rid of my 8210. I loved that little phone.
I guess the lesson is that greed doesn't get you anywhere!
Hey warrick ;)
Umart is only part-time at the moment, chris hired another guy at the same time who works when I'm not working doing the same thing. Basically as he needs an extra person in there 6 days a week. But its worked out well so far, allows me to do other things.
Believe it or not I don't think he owns a skyline either ;)
but Umart has been good so far.
GD68 ? what brand is that? or has nokia changed their naming.
my 8210 had problems when i first got it, but after they fixed it been fine ever since. And i've dropped it, got it wet, i think thrown it, and it lives
warwick: speak in emoticons -- see whehter you can do it! ;)
I'm with you guys on the phone thing, I only upgraded from a 5110 to a 8250 lol about 6 months ago.
The more gadgets and crap they have on them, the more inclined you are to use them for pointless crap which just hikes up your phone bill
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
