  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Nick,
hahahahahah, I Owned you at pool last night. I won every game we played, giving me a perfect winning streak against you. Games won by me 100% games won by you 0% lol. And I was so looking foward to seeing one of your so called patented "ass whoopings" or "smackdown fests" where you win like every game off the break for three hours running. But all I saw was you beating people who were too drunk to hold the que properly, and you screaming "SMACKDOWN" when you beat them. Might I add I was very dissapointed that your pool game doesn't stand up to the amount of trash you were talking. If you didn't mouth off so much I would have commented that you play an acceptable game. :thumbsup:
Yep, I'm going for dinner at the local bowls club, and then I'm settling down for a nice relaxing night of bingo. Did I tell you that I got myself some of those lucky trolls, with the whack hair and all. I have a good feeling about bingo tonight. I got my felt pens, and my ID, and I've ironed pleats down the front of my jeans, and I've got some brill creme for my hair..........
I think I'm as ready as I'll ever be.
:thumbsup:
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
