  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Definately the assignments, just looking at the requirements for this report I have to do tonight makes me want to go out.  Anyone?
why do you have to pick this time to go out when i have a 3 hrs long lecture coming up :D
give james or tze a call ... see what they got plans for :D
Jason,
Before I forget please accept my most heartfelt apoligies for going all 4wd last thursday when the GTR was behind my car.  When glen told me I did that I felt sooooooo bad. :D
Its all good, no stone chips, no problems. It was kinda in the danger zone, rocks flying and cars nearly getting reversed into it. It was more because of the situation than anything else.
I think that was the lesson of the evening. A gtst with a front mount is definately not a gtr. Thanks for not being mad.
cmon all you guys were whinging because nothing is organised for this week, suddenly i organise something and no one registers their interest!
build it and they will come :D
personally I dont give a **** where, when or how far...just tell me where to be and when....
sorry ska, was trying to flatten out my hair getting ready for my lecture.
i am definitely in... and you can also count in the regulars as well.... but dun expect the unexpected :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
