  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
everyone makes fun of me not owning a skyline :) just wait soon all you will be seeing is my after burners :devfu:
ben, calm down. what good is an 'after-burners' if you dun know how to control it. i will hate to see shit happens to you, esp if you are working hard to earn it.
