  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH YEAH
Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good! Coffee is good!
talk it up eh. And do I really get to meet your kids tonight? I reckon you would be an awesome dad to have. Wish my dad was cool. :)
Well I pick them up at 7pm at Burpengary, was thinking of meeting you guys at milton, but if we stop at a maccas, you know what kids are like, so just gonna scoot down the gateway, might bump into you near springwood, I'll have my radio on ch SAU just in case!!
Yeah kids are gonna be HIPPED UP so I gotta get HIPPED UP TOO!! Feeling all excited about having my kids for so long, never had my kids by myself for so long before, so yeah excited, but scared too, bah who needs that COFFEE WILL FIX THAT!!! mUUAhahah Hh ah ah HA H AH H AH H AH HA h AAAaa!
little dent on the back bar, not really noticeable but pissed me off nonetheless
and he tried to drive off without telling me, just lucky one of the guys saw him do it
In my last car I had some stupid tart in a 4wd with kids in the back reverse about 8 metres into my car despite me sitting on the horn for the last 4 seconds before she hit me. Then she drove off. Then when I finally got her to stop she told me that she hadn't backed into me. I was not happy. Only minor damege though.
Oh my, you're a father? I'd hate to be a kid that screws up right now.. :uhh:
Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee! Coffee!
Hipped up? Hyped up? is that some new slang that the kids are talking these days? Suddenly I feel so old and out of touch. :)
Yupp got two:
Kayla - 5.5 years old
Blake - 3.5 years old
And no I do not smack or yell, there is not point, just upsets the child and yourself more by resorting to that, just got to remain calm and think like a child and talk to them, thinking like a child is easy for me because I STILL AM ONE!!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
