  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
only an hour and a half left until we all go out bowling.  I had so much fun on the Bingo outing last week, and the $50 I won on keno.  Wow.
you wait till you see my new shirt with my name embroidered on the pocket......waaayy cool :D
