  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I don't think there is such a thing as a 4WD R33 GTS....that would either be a GTR or an R32 GTS4
Yeah there is , mate at work has a NA 33 4wd so I guess they call it a GTS still .
edit : sorry was re-reading the posts , bit to quick to jump in on the quote train there , my mate says it's slower going stright down the line against someone , but have a few round-abouts in the way and he will wip-ass.
