were you smiling??
i remember the first time i met warwick.. he's got this white T with redbull's logo on it...
he looks like an undercover cop trying really hard to look cool :(
lmao....I don't know if I was smiling...prolly not...he mighta thought I was trying to win on.....:D
I get that cop thing a bit....might have to shave my head...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
glenn yer pretty much, i dont mind waitin a little while for someone who we know but yer we stood round for a long time that night
I will give them the benefit of the doubt, it is hard showing up to a group of people you don't know and being open.
People handle that kind of stuff differently, people say I am Aloof when I first meet them, all I am doing is trying to see if I can work them out first.
And having a car that has been targeted for Theft (i.e my old 215 RWKW S13 had been attempted to be stolen twice) I am very hesitant about answering questions about my car to people I don't know.
As I said I will give them the benefit of the doubt, if things don't change then I will bucket them with you :(
What is everyone doing tonight, I vote we get a whole heap of HPI dvd's at some bbq meat and for those that want alcohol and have a HPI dvd night at Nex's, ALL IN FAVOUR SAY I
I
NAY
sorry guys I am staying at my G/F's tonight
I will make it for some other day though :(
