  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah I was thinking of that, just dun have tools to cut it out, plus talking with krawler last night bout it and it might be hard up against the bonnet, which means that padding will cover it anyway........ Johns got an awesome cf bonnet that has scoops right where the box is :D
hmmm...yeah....you might be right about the box hitting the bonnet
how much you want for the lid?
warwick why bother just cutting the top outta the lid? just screw the filter into the box using the rubber edges and some washers under the screws, dont over tighten, iirc thats how slips filter is held on
sounds like a good idea.....I have a pod attached to the stock box which I have butchered so the pod will fit in....kinda acts like a partition, but I went too far when butchering the lid and want to re-do it
ah k, mmm no hot air partitions for me, just my blue folder cover that everyone takes the piss outta
Bah that is high tech gear you got there James!!
thats way to expensive Ska  :D
Yeah better DOUBLE IT DEN!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
