  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Where is work exactly?
It's probably been posted before but what's the name of the shop and what street is it on...
its called AEROZ PIZZA CAfe
61 AERODROME ROAD, MAROOCHYDORE... JUST OPPISITE CHANDLERS X-SITE
its way funky and fun... so ya all have to come :wavey:
its like the local car enthusiast hang out....
Cheers... I'll organise something soon then...
Sounds good...
i used to own that shop.....   its a shit heap now..
well ill look forward to seeing yas all then :flower:
We ask'd the owner if they had a WRX, and they said the last owner did. Should have done the runner.. although we did already order.
