  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah, I was going to bring the GTST but the GF using that at the moment so I would have to wait for her to finish work.  Would be nice to lay down some times while the GTR is still stock.
YES YES YES You KNOW you want to :)
cyrus spoke to mum today she said i can put the mr2 up forsale end of the year, just set a price and if someone offers that or better take it. cause im not in the situation that i have to sell. so maybe an R34 could be on the agender?
NOW YOUR TALKIN! R34 mmMMmmMMmmMMmm BaBy!!
cant afford the r34 straight up, but i'll by a crap car to cruise around town and work in, pay my loan out, than try for a bigger loan and just get weekend insurance :)
what's this about weekend insurance?
never heard of that but is a good idea for a "weekend warrior" car
