  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glenn - Yeah I was talkin bout it yesterday arvo (couple hours ago) and he said he'd race me there, I asked if that meant he was going, but he did not respond??
hmm... he never mentioned it to me....
he called me this evening all excited and asked if i found a meeting spot for the brisbane crew for thursday food feast. and told me abt the new cb radios and how he is keen on trying them..
but no mentioned of Willo.
carefull what u wish for cyrus :D
Well in dat case:
1. 3 inch tubo back with high flow cat + install
2. FMIC + piping + install
3. front and back strut bars
4. In car UHF with antanne + install
5. Greddy Profec e-01 + Greddy e-manage + install and tune
6. Short shifter + install
7. Racing stripes (From MELV)
8. Green neon kit (From MELV)
9. Ajustable coilovers
10. front bar + side skirts anny BUT 400R + repray and fitting
11. misc internal plastic sprayed same green as used on exterior
12. high flow turbo or garret turbo
13. new clutch
14. wider tyres
15. wide body kit
but last ones are just wishes, but that is my shopping list at the moment, in that order I want them :P
hmm went quiet in here
Just arranging my shopping list for you :P problem is if you buy me any of the really expensive stuff I'll feel really bad, cause that is money you could be putting away for your own line!!
Ska... Your putting performance before rice... That's not like you...
Rice is just so much cheaper :P
Rice will prolly get done first cause it is the cheapest $80 for the racing stripes and $200 for the green neons from MELV :D
i tell myself i would be putting money away for my line but im just gonna wait till i start the new job..use the money i make at maccas for things when i move in
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
