  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Man I thought they were brave letting us follow them to this park in de middle of know where, and den they proffess they know how to fight, which excited and frightened me :) was waitin for a big black guy named BUBBA to come out and ass rape us...................... thank god dat didnt happen :D
