I bought some ramps yesterday to do my gearbox oil, then discovered I couldn't drive up them with my front bar, so had to do some dodgy manouvering so that they were on a downslope before I could drive up them....when the car was up on the ramps, the base of one ramp was like only half on the ground due to the dodgy incline......safety first:rofl:
* extremely slow clap*
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
james.. ya noe you will be the first one i called if we are going down....
but yeah... who you going with, Warwick?
thought I might go there with the missus on the way back from the airport....you wanna come?...prolly around the 8.30 mark
*remembers Glenn eats at midnight*
ok.... if you go @ 8.30. There's gonna be plenty of cars and ppl cos its friday nite. I reckon its best you parked @ the multistorey carpark.
you still got the address of the place? i will give you a call if i can make it down.
you sure its your wife and not some hot 18yr chick? :)
