  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
You have a mini... (mind my ignorance)
what year etc.
Special interest rego - what tha!
Its a 72 GT Clubman. Apparently 1 of only 1000 produced in Australia. All original and has had a complete ground up rebuild. Even one a couple of show'n'shine trophies.
If you are a financial member of a club and they can verify your car is what you say it is, and is over 30 yrs old you can qualify for this concessional rego. Its fairly restricted though, but fine for what I need.
cool got any pics?
One of the guys in the office here had a mini that he cut the top down (ie. the windows were only half their origonal size). It looked great, but really small. Had a lot of other performance stuff done to it, but can't remember atm. Said it went really quick and handled extremely well.
